traiano Posted October 24, 2017 Share Posted October 24, 2017 Hi family i have a geometry that went through a simulation, now in sops i have point position data, how is it possible to export an array of the position data across all frames of a desired point? Quote Link to comment Share on other sites More sharing options...
violalyu Posted October 24, 2017 Share Posted October 24, 2017 Hi Martin, Probably run a sop solver where you could give it a vector array and every frame push the P in the array? Quote Link to comment Share on other sites More sharing options...
traiano Posted October 25, 2017 Author Share Posted October 25, 2017 i will see if i try that, thank you Wanqi Quote Link to comment Share on other sites More sharing options...
3dome Posted October 25, 2017 Share Posted October 25, 2017 this might do it. no solver required dm_animPosArray_VEX.hip 1 Quote Link to comment Share on other sites More sharing options...
traiano Posted October 25, 2017 Author Share Posted October 25, 2017 Ok Dominik that seems to work but im not sure how to export.. Quote Link to comment Share on other sites More sharing options...
3dome Posted October 25, 2017 Share Posted October 25, 2017 On 10/25/2017 at 3:25 PM, traiano said: Ok Dominik that seems to work but im not sure how to export.. Expand export as what? textfile? can you explain please Quote Link to comment Share on other sites More sharing options...
traiano Posted October 25, 2017 Author Share Posted October 25, 2017 yes text file is ok i have 45k frames Quote Link to comment Share on other sites More sharing options...
traiano Posted October 25, 2017 Author Share Posted October 25, 2017 OK I found a way to export through CHOP Quote Link to comment Share on other sites More sharing options...
3dome Posted October 25, 2017 Share Posted October 25, 2017 ok. anyway here's a link to a neat file from @f1480187 which exports vector arrays nicely formatted http://forums.odforce.net/topic/30280-generate-text-file-out-of-houdini/?do=findComment&comment=169736 Quote Link to comment Share on other sites More sharing options...
traiano Posted October 26, 2017 Author Share Posted October 26, 2017 sounds great i will check it out danke Dominik Quote Link to comment Share on other sites More sharing options...
