colon in path
I have an object merge inside a sop solver that is inside an rbd sim. The object merge is pointing to the Geometry in the rbd object from the sim. with:
../..:rbdobject/Geometry
Why does this work with the colon? why isn't it another forward slash.
../../rbdobject/Geometry
I understand that its pointing at the rbd object which is different than the rbdpackedobject node. What does the : signify?
thanks
  • 2 years later...
I was watching this tutorial and finding out about this on 19:00, went on searching to find further explaination and found this empty thread.
So apparently, this is just the way it is when referencing a DOP network.
fills you with confidence when the tutorial presenter says "I don't know why, that's just how it is"
the reason for : is simple, you are not referring to the actual DOP node, for that you'd still use / , but you are referring to the DOP data within the dopnet as you see it in Geometry Spreadsheet or as it used to be called Details View
https://www.sidefx.com/docs/houdini/dyno/io.html#exporting-simulation-data-to-other-networks
Edited by anim
  • Thanks 1
