Luijee Posted October 28, 2017 Share Posted October 28, 2017 Hi, Can anyone shed some light on how to use the gasBlendDensity microsolver? I haven't seen a working example of it anywhere. Here is an example scene with the fields setup, trying to blend between 2 volumes. gas_diffuse_blend_example.hipFetching info... Cheers Quote Link to comment Share on other sites More sharing options...
ikoon Posted February 8, 2018 Share Posted February 8, 2018 As a part of my DOPs learning, I have tried to make a working example. I attach my working solution with a disclaimer, that I am not sure if I do it right. If anybody knows, and has time, please check my file for mistakes or bad practices. It is just few nodes. gas_diffuse_blend_example - v1.hiplc Quote Link to comment Share on other sites More sharing options...
Atom Posted February 8, 2018 Share Posted February 8, 2018 (edited) I think I would set it up something like this... Then you can just animate the Gas Target Force to control density morphing. ap_gas_blend_density.hipncFetching info... Edited February 8, 2018 by Atom 4 1 Quote Link to comment Share on other sites More sharing options...
ikoon Posted February 9, 2018 Share Posted February 9, 2018 Thank you very much @Atom ! I really appreciate, I walked also through your tutorial. Thanks a lot! Quote Link to comment Share on other sites More sharing options...
