jon3de Posted November 6, 2017 Share Posted November 6, 2017 (edited) I want to scale my packed primitives over time while they are simulated. In the attached hip file you can see I import the @active attribute successfully with a sop solver so that they are active around frame 70. In addition I want to scale them up first from e.g. 5% to 100% and update the transformation in dops. Unfortunately I cant get it to work. I´m not able to merge the transforms into dops in a way that it behaves correct. I also tried it with intrinsics "transform" attribute but without luck. I guess it has to be a combination with "transform" attribute and @P but there I got problems with the pivot and I wasn´t able to get correct results. I would be thankful for some help. kind regards jon scalePackedPrim_01.hip Edited November 6, 2017 by jon3de Quote Link to comment Share on other sites More sharing options...
rich_lord Posted November 7, 2017 Share Posted November 7, 2017 Hi, I don't have Houdini on me to look at your file, but I got scaling working in packed prims, and I put a file here: http://richardlord.tumblr.com/post/157573190741/hip-file-example-of-how-to-scale-packed Hope this helps. Sorry I cant look more closely at your problem. 2 Quote Link to comment Share on other sites More sharing options...
jon3de Posted November 7, 2017 Author Share Posted November 7, 2017 Thank you very much for the file Richard. Thats awesome. I always tried to replace the complete transformation of all the rbds. The idea to transform the actual transformation with a scale factor is nice. Instead of generating the scaling factor in the dop network I try to import it from sops e.g. a color channel. Unfortunately I still dont get correct transforms but your file gives me a lot new thinking approaches. Quote Link to comment Share on other sites More sharing options...
