kachoooxix Posted November 8, 2017 Share Posted November 8, 2017 Hi all, I am attempting to render out hair curves and only have them generate at the time of render. As I understand it, setting the hairgen node (created from a fresh scene from the shelf on a rubber toy object) render parameter to Hair Generation = "Generate Geometry in Mantra" is supposed to do just that. If I switch that parameter to "Use SOP Geometry", the hair renders out fine, but that defeats the purpose of not writing out the geometry beforehand and thus bloating the size of my IFDs. Otherwise none of the hair renders. Has anyone seen this happen or know what needs to be changed in the scene? Is this a bug? This is using HoudiniFX, v16.0.619 I cannot supply my scene file, nor screenshots, but this is happening in both my actual scene file and in a fresh launch of houdini with simple geometry as the only geo in the scene. Quote Link to comment Share on other sites More sharing options...
jon3de Posted November 8, 2017 Share Posted November 8, 2017 does the console give you any errors? Is your guide groom included for rendering? Quote Link to comment Share on other sites More sharing options...
Joshua Posted April 30, 2018 Share Posted April 30, 2018 Heyo! I'm sure you've probably figured it out by now, but for anyone having the same issue, It's cause you have to visualize the hairgen curves AND the guides to get it to render. I couldn't tell you why.. just how it goes lol 1 Quote Link to comment Share on other sites More sharing options...
