lisux Posted September 14, 2005 Share Posted September 14, 2005 I am experimenting some problems with the RotoShaoe and Rename COPs using H 8.0.360 in Windows. With RotoShape, if i maximize the viewer pane with the roto shape handlers visibles, houdini uses all the CPU, while doing nothing, and begin to get memory, up to 1 GB or more. And then if i restore the pane houdini crashes. So i think that is something wrong with this COP, i have posted this in the houdini forum but without luck at the moment. With the rename COP i don`t know if it is a bug or i`m missing something. I have an image with 3 planes: C, A and M, and i want to put the M values into the A plane, i can use other options like Swap COP for example; but when i want to do it using a rename COP, renaming M to A it do nothing. The A plane is the same and the M plane is still there. Somebody having the same problems there? Quote Link to comment Share on other sites More sharing options...
edward Posted September 15, 2005 Share Posted September 15, 2005 You're not nearly supplying enough details to the post on the H8 beta forum though. Quote Link to comment Share on other sites More sharing options...
lisux Posted September 19, 2005 Author Share Posted September 19, 2005 You're not nearly supplying enough details to the post on the H8 beta forum though. 21293[/snapback] Well the problem with the rename COP is simple, if i have C, A and M planes, and i rename the M plane to A simply when i see the A plane in the viewer i'm still seeing the original A plane not the data in the M plane, what it is supposed to be, i think. For the rotoShape COP, when i'm using it i have experimented some inestabilities, houdini crashes many time, and it only occurs with the rotoShape COP. For instance, if you maximize the viewer pane with the flag view put in a roto Shape, and then restore the viewer pane, the houdini crash. Houdini 8.0.353 Windows PS: I know there is a new version, i have to test it with the last version. Quote Link to comment Share on other sites More sharing options...
stevenong Posted September 19, 2005 Share Posted September 19, 2005 Hey lisux, We all like to post at odforce but I think it's best to post 8.0 related questions to the Early Access Forum so the developers can keep track easily. At least until 8.0 is released. Cheers! steven Quote Link to comment Share on other sites More sharing options...
