jackassol Posted December 3, 2017 Share Posted December 3, 2017 Hi, i have a copy stamp and wanted to build a look at function for the copys to a specific point or geometry - the rotation for each copy should be applyed only on the Y-Axis . Is there a special node for this? How does it work? all the best. jack look at.hip Quote Link to comment Share on other sites More sharing options...
Sepu Posted December 3, 2017 Share Posted December 3, 2017 Here you go. you need to subtract the 2 vectors I did a wrangle and Vop example. Also I'll use the copy to pts instead the stamp workflow. look at_Fix.hip Quote Link to comment Share on other sites More sharing options...
