Fox Posted December 12, 2017 Share Posted December 12, 2017 (edited) Hey Houdini wizards! 1) As the title implies, how do i reduce the number of particles visible in the viewport. When i upres wet sand particles and with a low particle seperation, even after caching it, it literally uses 64GB of ram at 15M particles and crashes my pc?! So, how do i reduce it in the viewport? 2) Is there an easier way to view the number of particles or points in the scene apart from middle mouse clicking the various nodes? Thanks Edited December 12, 2017 by Fox Quote Link to comment Share on other sites More sharing options...
fencer Posted December 12, 2017 Share Posted December 12, 2017 Are you using sprite representation or just points? 15m it's not big value for viewport. Quote Link to comment Share on other sites More sharing options...
Fox Posted December 12, 2017 Author Share Posted December 12, 2017 Hey paul, i'm actually using the default setting in which sprites are being displayed. Going back to the question, is it possible to reduce the viewport particle count like in Krakatoa? Quote Link to comment Share on other sites More sharing options...
mestela Posted December 12, 2017 Share Posted December 12, 2017 I don't think so, not as a display setting. You can branch off some nodes for viewing and do a random delete, while another node is marked as the one for rendering. delete_percentage_for_display.hip Quote Link to comment Share on other sites More sharing options...
