Hair and Fur - Not in the same spot
Short problem and question;
I have an object which is covered in fur - I've set a 'randomized' length of each hair strand.
I do not want to simulate this one, only it to follow the object.
Problem:
The fur is "randomizing" the length(and placement?) EACH frame it cooks. I do not want this behaviour, I want it to stay in its same spot throughout the movement.
Any one know about this?
-Moose
Sounds like you  use the guidegroom SOP on a deforming object, this will regenerate each frame with a new seed.
Groom on static rest and deform with the guidedeform SOP.
If it still doesn´t work... A .hip would help to solve the problem.
Aye, that was the issue, thanks a bunch!
Lots to learn. :-)
