[SOLVED]PolyExtrude Captial H?
Atom
I am having some problems getting polyextrude to produce any useful topology. Whether I extrude positive or negative the close corner of the letter H causes the green lines to crossover each other. When this happens I can not convert the result into a watertight VDB.
Is there some modeler trick to prevent the extrude crossover?
Edited by Atom
must be your normals...(at the corners, I guess it's not at 45deg hence cross over)
Here I'm using the 1st extrude to 'emulate' your path/skin, then the 2nd extrude works fine at the corners...
(have you tried sticking a fuse in after skin ?)
Edited by Noobini
Thanks for the double polyextrude tip. That does work well when you supply a curve. I linked the backbone curve point count directly to the 1st polyextrude divisions with an expression. This way if I deform the input curve the extrude will follow. I don't have to resample now because the initial line point count is the resample along the length.
Edited by Atom
