copy to points
mossawi
Hi guys,
I am following a tutorial from Entegma that ends with using the "copy to points" node.
I am using Houdini 15.5 and can't seem to find the same or similar node, any idea what I can use or if it has a different name?
Thanks a lot!
10 minutes ago, Sepu said:
it's pretty much the same, they just now in 16 forward split them up. I believe in 15.5 you have to turn on copy point attributes , which is off by default
Perfect that was it, works perfectly, thanks man! :)
