robertoandrea Posted February 11, 2018 Share Posted February 11, 2018 hi guys i have a problem about pyro shader. whenever i want to get render preview i see this error. i am using houdini 16. can u help me please? Quote Link to comment Share on other sites More sharing options...
robertoandrea Posted February 12, 2018 Author Share Posted February 12, 2018 anybody help? Quote Link to comment Share on other sites More sharing options...
toadstorm Posted February 12, 2018 Share Posted February 12, 2018 (edited) can you post your hip? also, if you're in H16, why is your flames shader in /shop/ context? was this brought over from an earlier version of houdini? have you tried creating a new flames shader in /mat/ context? Edited February 12, 2018 by toadstorm Quote Link to comment Share on other sites More sharing options...
robertoandrea Posted February 13, 2018 Author Share Posted February 13, 2018 this is my old pyro shader can't i use that in 16? Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted February 13, 2018 Share Posted February 13, 2018 The Pyro shader has changed. Use the new one. If you can't use the new one then open the scene in the version of Houdini it was created in. Major versions of Houdini will break reverse compatibility which is something to keep in mind (and a reason to hang onto old installer files). Quote Link to comment Share on other sites More sharing options...
robertoandrea Posted February 14, 2018 Author Share Posted February 14, 2018 ok thanks Quote Link to comment Share on other sites More sharing options...
