3d dash - orient to curve tangent when using Trail SOP
art3mis
Not sure if I should post this in Coding as the solution would be in VEX
Have a simple physics simulation with a box Primitive, Solver and  and Trail SOPs to create a 3d 'dashed line'.
The problem is my 'dashes' aren't oriented so that they are tangential to the curve.
Here is my initial VEX set up
@v = {5,5,0};
v@gravity = {0,-0.1,0};
My .hip is also attached.
Any VEX wizards able to help?
Am familiar with Parallel Transport to compute normals on curved lines
 http://www.entagma.com/td-fundamentals-parallel-transport/#more-1145
but was hoping there was a simpler solution that allowed use of the Trail SOP.
3d_dash.hiplc
Edited by art3mis
