evanrudefx Posted February 18, 2018 Share Posted February 18, 2018 Hey! What is wrong with my setup? I am just trying to use a source volume node to add turbulence to my sim. However, I can't get it to work! Any help would be amazing. Thanks, flip.hipnc Quote Link to comment Share on other sites More sharing options...
Sepu Posted February 18, 2018 Share Posted February 18, 2018 In Flip is much better to control your forces or velocity through pop since they are pts, you can create your own forces or update velocity through POP VOP or POP Wrangle, or you can use the pop force, wind, etc. 1 1 Quote Link to comment Share on other sites More sharing options...
evanrudefx Posted February 18, 2018 Author Share Posted February 18, 2018 On 2/18/2018 at 9:13 PM, Sepu said: In Flip is much better to control your forces or velocity through pop since they are pts, you can create your own forces or update velocity through POP VOP or POP Wrangle, or you can use the pop force, wind, etc. Expand I see. I tried pop forces before, but I accidentally plugged them into the volume velocity rather than the particle velocity. Thanks for the suggestion!! Quote Link to comment Share on other sites More sharing options...
