art3mis Posted February 21, 2018 Share Posted February 21, 2018 Not having any luck getting gConvert in the Houdini terminal to convert a .bgeo to an .obj I think my interpretation of the documentation is incorrect. Can anyone provide an actual example? for instance I've tried $ gconvert -l 10 input.bgeo output.obj gconvert [-l lod] infile outfile Quote Link to comment Share on other sites More sharing options...
LaidlawFX Posted February 22, 2018 Share Posted February 22, 2018 This did the conversion, when I used the toy horse. D:\>gconvert test.bgeo test.obj and this worked too but not change with playing with the lods. D:\>gconvert -l 1 test.bgeo test.obj However I'm not sure what the level of detail does fully... I'm guessing it probably has to do with the non-polygon to polygon conversion. I tested it on a nurbs sphere, where I RMB and saved it to disk, and then ran the command at -l 0 and -l 2 and it changed the file size on disk. D:\>gconvert USAGE: gconvert [-t outformat] [-l lod] infile outfile -l lod Level of detail for conversion -t fmt Output format type This program converts geometry files from one format to another If a level of detail is specified, all geometry will be converted to polygons at the detail specified Quote Link to comment Share on other sites More sharing options...
