flip fluid cache
aksdrv
 Hello, I am working on flood sim,i want to simulate the main flip, and use cache files to simulate whitewater faster, without having to re-sim the main flip. Can anyone describe this workflow detailed in Houdini 15.5, or create a project file with this setup?
i'm exporting my simulation cache using an "Rop_Output_Driver"
Edited by aksdrv
White water references the compressed cache. This is the first cache I generate. I don't keep .sim files. After I generate the compressed cache I generate the surface cache for the fluid. If you change the sim in any way, you have to regenerate both caches. So I work out the basic flow of the fluid at a high particle separation then lower the particle separation and generate caches.
Edited by Atom
