Enviro variables
Houdini uses environment variables in a Unix like way and if the environment variable is set before launching Houdini then it'll use it. See the documentation on it if you haven't already.
http://www.sidefx.com/docs/houdini/basics/config_env.html
The short answer is yes, if you define PATHA variable as "/1" then any time you use $PATHA it'll get replaced with "/1" in the text. Beware using variables that look like $PATH because that's a critical system wide environment variable. Ideally it would be something not close at all to existing variable names to avoid any confusion.
https://en.wikipedia.org/wiki/PATH_(variable)
