CinnamonMetal Posted March 10, 2018 Share Posted March 10, 2018 The attract points node within a POPNet attract a point to another point. What if one of the points is representing a primitive; how could I get the four points of a quad primitive to snap to the nearest points of a polygonal sphere; while the point of the quad primitive is directed by a POPNet. I hope that was understood. Remember there two different set of points / point, one is controlled by a POPNet, the other is the Primitive which is made up of the point. When the point representing the quad primitive is within distance of a sphere, for example; the four points on the sphere meet with the nearest four points on the sphere. I was thinking of opening the point cloud of the primitive but I don't know how to get attract points within a POPNet to use the point cloud of the primitive rather then the point representing the primitive ? Quote Link to comment Share on other sites More sharing options...
moneitor Posted March 10, 2018 Share Posted March 10, 2018 maybe with a draw or something would be easier to understand what you need. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 10, 2018 Author Share Posted March 10, 2018 The attract points node within a POPNet uses the middle point of a primitive or more then one primitive to attract its self to the points of the target geometry in my case. Rather then the one point which is center of the primitive; the four points of the primitive are used instead, attracting them-self to the target geometry ? Quote Link to comment Share on other sites More sharing options...
Atom Posted March 10, 2018 Share Posted March 10, 2018 (edited) Here is an example scene with various ways to get points on a surface. BLUE = Vertex RED = Primitive Center GREEN = Scatter PopAttract works a lot like PopSteerSeek in the fact that you can override the goal variable (a fixed vector at world origin) with a companion goal point via VEX code. A particle can only be attracted to one point, not four, but each particle can have it's own unique goal on a surface. ap_points_buffet.hiplc Edited March 10, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 11, 2018 Author Share Posted March 11, 2018 If a point can only be attracted to one point, but the one point controls a primitive made up of three or four points; is there a way to get those three or four points of the primitive to snap to the nearest points on the target mesh ? Quote Link to comment Share on other sites More sharing options...
Atom Posted March 11, 2018 Share Posted March 11, 2018 But what is the nearest point? If you want the center point of those 4 points just use compute dual as I have shown in the example file, represented by the red points. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 11, 2018 Author Share Posted March 11, 2018 The nearest point which would be the three\four points of the primitive which come close to the target mesh. I have the center point for each primitive; if the center point is controlled by the POPNet; how can I get the three/four points that make up the primitive to which the center point is controlling to attract to the nearest point of the target object; whatever the target object is, let say in this case a sphere ? Quote Link to comment Share on other sites More sharing options...
Atom Posted March 11, 2018 Share Posted March 11, 2018 Just fetch the primitive then get the points. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 11, 2018 Author Share Posted March 11, 2018 Sorry, what do you mean by fetch ? Quote Link to comment Share on other sites More sharing options...
Atom Posted March 11, 2018 Share Posted March 11, 2018 Why don't you just post a scene of what you already have? Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 11, 2018 Author Share Posted March 11, 2018 In the scene, you'll see the primitive which have a center point; attract to the nearest point on the sphere. Although what I want is for the four points as well on the primitive to attract to the nearest points on the sphere. Unless someone has another solution to this ? One caveat, I realize that more sub-divisions on the sphere will be required unless the goal is to have the points on the primitives to stretch to the nearest point on the sphere. LoopDeletePrim2_odup.hipnc Quote Link to comment Share on other sites More sharing options...
Atom Posted March 11, 2018 Share Posted March 11, 2018 (edited) So you want the rectangles to conform to the sphere? Perhaps you could make the rectangles cloth then set the sphere as a collision object for the cloth but make the cloth rectangles seek the center of the sphere. If you want the rectangle to stretch to fill the area of a primitive on the sphere check out this link. Edited March 11, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 11, 2018 Author Share Posted March 11, 2018 Actually, using cloth is something I considered. Quote If you want the rectangle to stretch to fill the area of a primitive on the sphere check out this link. The link you posted, fills the primitive with an object. I want the primitive to, I guess you could say; snap to the nearest point on the sphere. The center point, snaps to the nearest point on the sphere, while the other points on the primitive snap to the other nearest points on the sphere Quote Link to comment Share on other sites More sharing options...
Atom Posted March 11, 2018 Share Posted March 11, 2018 You could make the object a rectangle. It does not have to be an irregular shape. Is the snapping part of the animation (like one part first, then the other parts) or is that just a descriptive word to indicate the modeling locks in. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted March 11, 2018 Author Share Posted March 11, 2018 Quote Is the snapping part of the animation (like one part first, then the other parts) or is that just a descriptive word to indicate the modeling locks in. You're on track with the first part of what you said; then again not quite sure what you meant by "the modeling locks in". Did you mean piece by piece ? 3 minutes ago, Atom said: You could make the object a rectangle. It does not have to be an irregular shape. Going by the link which you posted, if that is what you're referencing; I hope. I want the primitive too not snap as it to look clean. By it finding the nearest point on the sphere then as you mentioned in what I quoted above, things are not clean and look more natural when the other parts come into play so to speak. Quote Link to comment Share on other sites More sharing options...
