Best approaches to achieve an organic voronoi holes pattern
spieluhr_x
Hello everybody,
What would be the best way to approach the effect like the reference images? I would like to have some sort of control to blend solid parts and drilled parts like in the second image.
Edited by spieluhr_x
To simplify the question
Starting from a human bust model:
Paint density using Paint SOP --> Scatter (enable Density Attribute) --> copy spheres on scattered points (Sphere SOP, Primitive Type: Polygon or Polygon Mesh).
On another branch PolyExtrude char surface so it has thickness (enable Output Back).
Boolean (Operation: Subtract) with extruded char on left input, spheres on right.
You can jitter the spheres' P (Point Jitter with a small scale, maybe 0.05 as a starting point) and randomize an orient on the points (Attribute Randomize, Attribute Name: 'orient', Dimensions: 4) before Copy To Points for a bit of randomness. And/or after Copy To Points use an Attrib VOP with e.g. Unified Noise added to @P, which will possibly give a nicer-looking randomness. For nicer edges after Boolean enable Output Edge Groups: 'abseams' on the Boolean and use PolyBevel with Group: 'abseams'.
Maybe helps you get started, try it out. If you get stuck, ask again, I'm sure I'm missing some details :)
My proposed solution wasn't very good. Tried it out and ultimately had better luck with:
Head mesh --> PolyReduce (paint an attribute before to Retain Density in some parts) --> Divide with Compute Dual on --> some extrudes & peaks & vdb and back and such to get a nice solid shape.
or
Head mesh --> Scatter (paint density before) --> Voronoi Fracture (Create Inside Surface off) --> some extrudes & peaks & vdb and back and such to get a nice solid shape.
Quite far from the refs, I headed a different direction due to needing similar stuff for a project.
