jeremyr03 Posted March 22, 2018 Share Posted March 22, 2018 Hi, I looking for a way to export points/particles from houdini to maya. Houdini 16.5, Maya 2017. I've tried exporting in alembic, importing in maya with exocortex, but nothing work. Houdini digital asset is not a solution for me (render farm, licenses ...). Any solution ? Thanks a lot Quote Link to comment Share on other sites More sharing options...
Sepu Posted March 22, 2018 Share Posted March 22, 2018 (edited) you can also use load the abc as a proxy depending of render that you will use. Edited March 22, 2018 by Sepu Quote Link to comment Share on other sites More sharing options...
jeremyr03 Posted March 22, 2018 Author Share Posted March 22, 2018 Hello Sepu, I render with Arnold. The probleme is that if a export my particles as ASS, in maya if i load my ASS i can not instanciate different object on particles for example. Thanks Quote Link to comment Share on other sites More sharing options...
Sepu Posted March 22, 2018 Share Posted March 22, 2018 Not sure if you gonna be able to instance even if you use .abc, you will want to do that with houdini engine, you could probably create an OTL. Another option will be doing all the instance in Houdini and export that to Maya, however that will get heavy and expensive. Quote Link to comment Share on other sites More sharing options...
jeremyr03 Posted March 23, 2018 Author Share Posted March 23, 2018 Ok thanks Sepu. I will choose the heavy options. Exporting ass. Quote Link to comment Share on other sites More sharing options...
haggi Posted March 23, 2018 Share Posted March 23, 2018 Or you could ask the creator of http://redpawfx.github.io/partio if he is able to provide a version for Maya2017. He has a particle emitter in his toolset. Quote Link to comment Share on other sites More sharing options...
jeremyr03 Posted March 23, 2018 Author Share Posted March 23, 2018 Hello Haggi, Wes i've tried to build partio from the sources for Maya 2017 without success until now. You'r right I will ask redpawfx. Thanks Quote Link to comment Share on other sites More sharing options...
