keddefar Posted April 6, 2018 Share Posted April 6, 2018 Hi folks Im a Houdini-noob, but somewhat techsavvy nerd, tryin to learn Houdini by fiddling with it, building stuff! atm tryin to re-create the "sharing" system visualised w the gif here ( i originally created it w pflow dataops in 3dsmax, but a fine case for houdini i thought ) idea of the system is each point representing a unit with a certain amount of energy if a point have a overcapacity of energy its look if a neighbour nearby is in need of energy if a energy-wealthy point sends energy to another, its withdrawn the amount of energy the lucky energylacking neighbour receives probably a deep plunge but thought, Hey I can easily write this w vex wrangles inside a SOP solver and voila - turns out not so easy... I sort of solved the exchange of energy btw groups of points, but struggle with visualising the "sent" energy as a "extra point flying from the energy-wealthy point to the energy-lacking one... seems fx i cant assign a velocity to the extra added point, only move it by moving its position Am i taking the totally wrong approach to this or is there hope? sharing v01.hipnc 1 Quote Link to comment Share on other sites More sharing options...
j00ey Posted April 6, 2018 Share Posted April 6, 2018 I had a quick look at your scene, looks like it's more or less there. In terms of adding the energy transfer itself I'd do it as a post process - eg in the SOP solver you could group the points that are emitting and store the frame number when the transfer begins as an attribute, eg 'emit_start', then after the solver, for each point in the group add a point every frame for say 5 frames after emit_start and lerp the position between P and your tarpos attribute. over another 5 frames. That's probably a bit garbled. Basically I think it's easier not to add the points inside the solver, do it afterwards. Quote Link to comment Share on other sites More sharing options...
mestela Posted April 6, 2018 Share Posted April 6, 2018 wot tim said. sharing_emit_points.hipnc Quote Link to comment Share on other sites More sharing options...
