Explosion in Farm Rendering
Hi everyone! I'm here with another rookie question (drum roll)
I"m working on my 2nd year project.
I attached my project file, the problem is i have both my destruction and explosion simulations cached. But when i upressed and textured after that, it slowed down crazily.
I'm using my university's render farm and my renders are taking an hour per frame! (Which we can't render anything that takes more then an hour per frame, it automatically fails)
Any suggestions how i can lower down the render time or is there smarter way to approach this upres and texturing than i did as i don't really feel like i did it the right way.
Thank you for reading, i'll continue crying in the corner until someone replies....
DESTRUCTION_RENDERS.hipnc
There are many things, why it's rendering how it's rendering. 1h for real production is no long at all.
You can try to cheat with the farm limit time by using "tiled render".
mmm, all your Mantra render settings are left as defaults.
You'll need to optimize each Mantra ROPs individually to decrease render times.
Make sure you turn off anything that you don't need, eg: if you don't need reflections/refractions/SSS, set your limits to 0
for the explosion render, try reducing your Volume shadow quality set 0.25 for example, that really speed things up.
Also Environment lights are really noisy especially for volumes, you can achieve similar lighting with 2 or 3 disk lights and get a lot less noise/ faster renders. And stochastic samples should be higher than 4...
hope that helps
  • Thanks 1
Tiled rendering rocks! Technically it's taking more time to render in total but sure worked for me to cheat the farm limit time. Thanks a lot!
hope that helps
You're right, i'm still trying to learn how to use Mantra properly. I used your advice + tiled rendering into 4 pieces. Now i get about 30-45 mins per frame. Thanks for the help!
