Houdini 9 Wish List
Jason
Don't forget you can still add the fine detail on top of any system by using a displacement after the deformation. Even with all the capture stuff I've played around I can see having a pose based system can add some candy on top of what you can get with even the most sophisticated capture system. And you wouldn't really want to be moving around millions of polys would you? Surely you need something more realtime?
25981[/snapback]
Just for the Poses would you want millions of polys for the actual animation low poly and render high detail displacement maps based on the poses.
Cheers,
Nate Nesler
  • 4 weeks later...
  • Replies 186
  • Created
  • Last Reply
Top Posters In This Topic
How hard would it be to add colour coding to parameters in Houdini? This could provide a big workflow aid for artists working on complex pipelines in production. Some of the assets or shaders we use run to hundreds of parameters and colour coding would be an easy way to prioritise them or group them semantically.
For example, some settings might be coded one colour to indicate that they should not be changed without supervisor approval or another colour might indicate those parameters that should be adjusted first. Alternatively, in an HDA a colour may indicate controls that adjust shape or controls that adjust translation, etc. You get the idea...
26647[/snapback]
Ahh, yes; this would be nice; any assigned colors could carry across to the Channel Editor too. I believe this would tie in with the thread on the SESI forum.
http://www.sidefx.com/index.php?option=com...iewtopic&t=5513
