lisux Posted January 10, 2006 Share Posted January 10, 2006 Hi all. I am playing with custom panels to easu the use of the texcache command through an ui. My problem is how to control the initialization of the panel i have created. I have a custom panel saved in my $HOME/houdini8.0/custom folder, i want that when the panel is opened some label widgets get the value of the next commands: texcache -l texcache -s So ones can view the actual txture cache state. Even more i want to initialize some sliders to the actual cahe size, res, etc. It is possible to do it? I am used to make MEL interfaces for Maya, but custom panels in Houdini seems to be complitely different Thanks Quote Link to comment Share on other sites More sharing options...
hoknamahn Posted January 10, 2006 Share Posted January 10, 2006 Hi all.I am playing with custom panels to easu the use of the texcache command through an ui. My problem is how to control the initialization of the panel i have created. I have a custom panel saved in my $HOME/houdini8.0/custom folder, i want that when the panel is opened some label widgets get the value of the next commands: texcache -l texcache -s So ones can view the actual txture cache state. Even more i want to initialize some sliders to the actual cahe size, res, etc. It is possible to do it? I am used to make MEL interfaces for Maya, but custom panels in Houdini seems to be complitely different Thanks 23506[/snapback] Use custom operators with callback hscripts. You can get info using backticks like `texcache -l` and then you can parse that info and "write" it to the label value. But there is one problem - UI refresh. You can't get the nice refresh of the labels But that was in H7. Maybe in H8 something changed. Or you can try Tcl/Tk or Perl/Tk way Quote Link to comment Share on other sites More sharing options...
lisux Posted January 12, 2006 Author Share Posted January 12, 2006 Use custom operators with callback hscripts. You can get info using backticks like `texcache -l` and then you can parse that info and "write" it to the label value. But there is one problem - UI refresh. You can't get the nice refresh of the labels But that was in H7. Maybe in H8 something changed.Or you can try Tcl/Tk or Perl/Tk way 23508[/snapback] The callbacks for the labels are called when it is displayed? I have use the message command in a label callback and it is not executed anytime. If i use a button with a callback that refresh the label of the label gadget i can do it. Thanks Quote Link to comment Share on other sites More sharing options...
