What Is This???
hoknamahn
Hey guys!
Does anybody know what is the window, titled as "Detail" is ment for?
The window is black-colored, devided into 4 parts by double lines. I can't really explain how I got it. I suspect that I had a Object Type Properties window opened and a cursor over the input field - then I tried to type "meta..." - and suddenly I got this window materialize. I tried to replicate this but no luck. What is worse - I didn't make any screen-shots :( I never ever saw it before.
You're looking at the COP viewer / Mplay image detail window, which you probably popped up with a stray 'm' key in the viewer.
23816[/snapback]
I managed to split the IPR viewer too - and couldn't figure out how to unsplit it. Any idea, Mark? Does it even make sense to be able to do it in the first place?? There is no stowbar with the little split window icons.
