Hi can someone help me, every time I create a POP collision detect and then I create a pop replicate to create more particles from the collision, it works perfectly, the problem is when I create a static Object for the particles to bounce on the geometry the pop colllision detect and behaviour stop behaving and I dont know what to do to make it work, does someone have a solution?
Maybe it’s the setup of your collider : use volume when you work with particles.
I am also wondering if it is necessary to use static solver and static object to get bounces : maybe you can use the POP Collision behavior ? Not sure...
By the way, Jeff Wagner speaks about that in the first 20 minutes of this video :
Hope this helps
Edited by StepbyStepVFX
