Recompute topology after projection on a plane
AntoineSfx
Say I project a platonic solid on a grid using ray.
How to remesh that set of points and edges so that the new topology matches the apparent (visual) one ?
It would be something like compute all the self intersections, divide all the edges that intersect each other, and recompute all the primitives.
Is there a node that already does that ?
Here is an example: the projected icosahedron still has the edges and points of the original icosahedron
I would like to have one primitive per apparent polygon, and one point at each edge intersection.
Edited by AntoineSfx
4 hours ago, AntoineSfx said:
I edited the question.
I am not quite satisfied with my solution (resample heavily, Fuse where geo cross itself, and delete points that have less than 3 neighbours). This is a "dirty" trick...
It may not work if you project geo that is 2D, but for volumes each point has always 3 neighbours, and so its projection (except if you project perpendicular to a symmetry axis...).
Here is the file
vu_flatten_v2.hipnc
Here is the file
vu_flatten_v2.hipnc
So this is not really working, the final assembly is not a set of non overlapping primitives.
Maybe something with the constraints in triangulate2d to force the edges location
