Stick points on an animated alembic
Hi there,
I'm trying to stick points on an animated alembic without the points moving all over the place.
At the moment I've got my alembic attached to a vdbfrompolygons to scatter.
How can I make sure that these points will follow the alembic geometry? (the polycount doesn't change while animating)
Thank you for your time and help.
(I've attached an alembic file)
AlembicTestFile.abc
one method:
1) timeshift your geo to any static frame
2) scatter points, in the OutputAttribs tab turn on the first 2 options
3) put down Attribute Interpolate and put your points in first input, deforming geo into second input
  • Thanks 1
5 hours ago, 3dome said:
one method:
Hi 3dome, Thanks for your help.
I went and tried this out but I'm only getting one point that seems to move with this result.
I've attached a zip with the Alembic I use and the hip file with your solution.
Fixedscatter_01.zip
6 hours ago, Sepu said:
use the point deform when scatter with volumes, also u need to unpack your geo
fixedscatter.hipnc
Thank alot Sepu,
Based on a few options I've come across another option by using an attributeVop and calculating the xyz dist.
The point data seems to animate a bit smoother this way.
FixedScatter.zip
  • 3 weeks later...
You could run this snippet in a wrangle:
int posprim;
vector param_uv;
float maxdist = chf("maxdist");
float dist = xyzdist(1,@P,posprim,param_uv,maxdist);
vector pos1 = primuv(1, "P",posprim,param_uv);
vector pos2 = primuv(2, "P",posprim,param_uv);
@P = pos2+(@P-pos1);
The scatted points in the firstinput
Rest Geo in the 2nd
And deforming geo in the 3rd
Edited by kevidahevi
  • Thanks 1
