CinnamonMetal Posted May 15, 2018 Share Posted May 15, 2018 I can't get two attributes to display in the viewport. I can get one attribute to display but not two when the second attribute is created within a condition ? Quote Link to comment Share on other sites More sharing options...
Yon Posted May 15, 2018 Share Posted May 15, 2018 You mean within a loop? Define it outside the loop. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted May 15, 2018 Author Share Posted May 15, 2018 I'm creating the attribute within a condition (if); but I don't think it's getting created otherwise viewing the attribute by means of visualization in the viewport would show the attribute ? Quote Link to comment Share on other sites More sharing options...
Atom Posted May 15, 2018 Share Posted May 15, 2018 (edited) You can't really conditionally create attributes, they either exists on all points (prims etc...) or they don't. You can conditionally set values on a previously created attribute. If the attribute does not exist, it will be created when first referenced and set to a default value (typically zero). In your current setup if your condition is never met then the attribute will never be created because it will have never been referenced. Edited May 15, 2018 by Atom Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted May 15, 2018 Author Share Posted May 15, 2018 @Vector_Pt_AC = Desired_Vert_A - VertM_A; That line of code will display a vector in the viewport int chngePrim = detail(0,"iteration",0); if(chngePrim%2==1){ @Vector_Pt_AC = Desired_Vert_A - VertM_A; } The above block of code when placed within detail wrangler wrapped within a forEach SOP with the forEach metadata node connected to the second input of the detail wrangler; does not show a vector attribute ? Why does one work and not the other; when the second block of code is the code I want; rather then the first line of code ? I have a scene to demonstrate this and it has been frustrating as to what is going on ? Quote Link to comment Share on other sites More sharing options...
toadstorm Posted May 15, 2018 Share Posted May 15, 2018 Keep in mind that for vectors, you need to preface your attribute name with "v", as in "v@Vector_Pt_AC". Also, your "iteration" metadata is likely not on the input 0. If you've created an Import Metadata node from your For-Each block, you'd connect that to the second input of your wrangle and reference it like so: int chngePrim = detail(1, "iteration"); Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted May 16, 2018 Author Share Posted May 16, 2018 As mentioned elsewhere; In the scene attached, you will see a purple vector that is 90 degrees to the yellow vector. Go into the primitive wrangler node and comment out the last line within the primitive wrangler node. The purple vector disappears. Go into the detail_modulo node wrangler node which is between the begin and end forEach SOP block. When checking the geometry spreadsheet for the detail_modulo wrangler you see three vectors; the purple line has disappeared ? Why has it disappeared; when the forEach SOP is iterating over every primitive and with that known each primitive should have the purple vector line, considering the attribute it is created within the condition (if statement) ? At this point the last line within the primwrangler node should be commented out. I understand that the attribute created within the detail_modulo is a vector node and that the attribute created contains two integers but remember; the line you commented out from the primwrangler node is identical to that line within the condition (if statement) of the detail_modulo node, except no purple vector is shown ? When I mention purple vector, it's just the color I gave the vector in the viewport it has obviously no importance the color of the vector in the viewport, it's simply for description purposes. Vector from Vertice.hiplc Quote Link to comment Share on other sites More sharing options...
toadstorm Posted May 16, 2018 Share Posted May 16, 2018 The .hip file you attached doesn't have anything in it other than a grid with a single primitive wrangle attached. There's no foreach loop here at all. Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted May 16, 2018 Author Share Posted May 16, 2018 Sorry everyone; I could be the scene file had spaces. I hope this scene works. aVectorfromVertice.hiplc.hipnc Quote Link to comment Share on other sites More sharing options...
toadstorm Posted May 16, 2018 Share Posted May 16, 2018 Your import metadata node had some kind of error, it looks like the Block Path value was improperly defined. If you delete it and create a new metadata node, the vector attribute appears correctly. That said, the code you currently have isn't going to do much. First, it's a Detail Wrangle, so you can't expect bound attributes like "v@Vector_Pt_AC" to work correctly, since those were previously defined as primitive attributes. You'd have to use prim() and setprimattrib() functions to get and set values on primitives from a Detail Wrangle. Second, the "i@opinput0_Desired_Vert_A - i@opinput0_VertM_A;" expression won't return anything meaningful, because neither of those attributes exist at all, let alone as detail attributes. Assuming those attributes did exist as primitive attributes, again, you'd have to use prim() and setprimattrib() in your Detail Wrangle in order to set values, because you're not iterating over primitives in a Primitive Wrangle. If the only reason you're using this for-each block is to apply your code to every other primitive, you're way better off defining a group comprised of every other primitive, and then setting that group as a mask for a Primitive Wrangle. 1 Quote Link to comment Share on other sites More sharing options...
CinnamonMetal Posted May 16, 2018 Author Share Posted May 16, 2018 (edited) On 5/16/2018 at 2:39 PM, toadstorm said: Your import metadata node had some kind of error, it looks like the Block Path value was improperly defined. If you delete it and create a new metadata node, the vector attribute appears correctly. That said, the code you currently have isn't going to do much. First, it's a Detail Wrangle, so you can't expect bound attributes like "v@Vector_Pt_AC" to work correctly, since those were previously defined as primitive attributes. You'd have to use prim() and setprimattrib() functions to get and set values on primitives from a Detail Wrangle. Second, the "i@opinput0_Desired_Vert_A - i@opinput0_VertM_A;" expression won't return anything meaningful, because neither of those attributes exist at all, let alone as detail attributes. Assuming those attributes did exist as primitive attributes, again, you'd have to use prim() and setprimattrib() in your Detail Wrangle in order to set values, because you're not iterating over primitives in a Primitive Wrangle. If the only reason you're using this for-each block is to apply your code to every other primitive, you're way better off defining a group comprised of every other primitive, and then setting that group as a mask for a Primitive Wrangle. int v_c; int chngePrim = detail(1,"iteration",0); if(chngePrim%2==1){ v@Vector_Pt_AC = prim(0,"Desired_Vert_A",0) - prim(0,"VertM_A",0); setprimattrib(0,"Vector_Pt_AC",0,"set"); } Using the prim() and setprimattrib() function within the detail wrangler (detail_modulo) as you mentioned and it should create the vector (purple vector as mentioned) per primitive, correct ? Edited May 17, 2018 by CinnamonMetal Quote Link to comment Share on other sites More sharing options...
