Andrea Posted May 21, 2018 Share Posted May 21, 2018 Hi, I've done an RBD simulation using packed low-res geometry and saved them as points. Then I've increased the resolution of the pieces and saved them to disk (the usual workflow). Now I'm loading the hi-res pieces back as Packed Disk Primitives and I would like to copy the geometry on the simulation points. I can't load them in any other way because the scene starts to be very slow. When Packed Disk Primitives are loaded in houdini, they don't show the attributes (just the path,P, and the intrinsics). For instance them in the correct way to the simulated points I need their name loaded in Houdini (I can't use ptnum). Is it possible? p.s: I've found a workaround using the name of the low-res geometry for find the correct point, but it requires an extra step I would like to avoid Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 21, 2018 Share Posted May 21, 2018 You can use the Instance SOP. Just supply the path as a string attribute on the cached lowres points, that points to the correct highres piece on disk. 1 Quote Link to comment Share on other sites More sharing options...
Sifis Posted January 21, 2020 Share Posted January 21, 2020 (edited) Hi Skybar, I have the same problem. Can you elaborate more on this method? Thanks in advance. Edited January 21, 2020 by Sifis Quote Link to comment Share on other sites More sharing options...
Andrea Posted January 21, 2020 Author Share Posted January 21, 2020 (edited) Here is an example. Of course if you need to load the instances on moving points, for example after an RBD simulation, you need to save also attributes like transform, pivot.. with the points. Also before saving the pieces to disk you can do any kind of upres operations load_instances.hipnc Edited January 21, 2020 by Andrea Quote Link to comment Share on other sites More sharing options...
