LIDAR to Heightfields
They say that if you want to work on your Lidar point cloud as a VDB primitive you have first to convert it using Convert VDB Points SOP.
Under the hood, heigthfields are 2D volumes data , so I guess I would : import your files with Lidar Import, then convert to VDB, then to volume and play with volumes wrangles to transfer data from this volume into a 2D volume called heigth.
That’s not straightforward but it seems this is the only way
12 hours ago, bunker said:
You can also use a volumefromattrib SOP to copy the height to the volume
VolumeFromAttrib works pretty well. Thanks Illusionist. I also tried VDB route and tiaingulate2d (which I had forgotten about). VDB required a decent amount of fiddling but did a great job and roughly the same memory / time to process as VFA. Trianglate2D became unhappy after a couple millionish points so I didn't get anywhere with it.
