flipbook with simulation time
Hi, is there any way to make a flipbook and print out the current time through vcomment?
I want to save the sequences and remember the simulation time.
I found a python script that gives me the system time, but I cant use getattrib or detail in viewport comment.
any idea Please???,
Thank you Nikos
Thank you Atom,
I had found this command in the forum but I couldn't make it work :(
what I'm doing wrong?
I also tried to export file sequence with this ->$LT Local time - not including stretch or offset<- in the file name... No luck :(
  • 7 years later...
On 6/13/2018 at 4:25 AM, Atom said:
You could parent a font object to the camera and use it to create a custom overlay.
Paste this code into the font text field.
`system("date +%X")`
First up apologies for digging into a very old post here.. I've recently been looking for something similar, so it's great to find this thanks @Atom ! This somewhat works in the viewport comment by displaying the current time, but for me it does not update per frame when flipbooking or dragging through the timeline.
@nikosgr00 Your solver method is working well and does update per frame when dragging the timeline, as well as when flipbooking.
Between these two versions I'd love to know if it would be possible to instead of showing the current time of day, it could show elapsed time starting from zero seconds. Any ideas on calculating the math behind that?
Edited by GlennimusPrime
