MaximTF Posted July 3, 2018 Share Posted July 3, 2018 Hi, there. I have a little issue with FBX export. I made some points with random position and rotation. And i wanna use it like pivots in Unity. First of all i use RBD to FBX rop to separate points. And it works well. For positions, but rotations are zero. For example, when i export to alembic, then from alembic to fbx in cinema, i have right positions and rotations. How could i delete alembic and cinema from my pipe? 1 Quote Link to comment Share on other sites More sharing options...
Spike Posted September 12, 2018 Share Posted September 12, 2018 On 03/07/2018 at 7:21 PM, MaximTF said: Hi, there. I have a little issue with FBX export. I made some points with random position and rotation. And i wanna use it like pivots in Unity. First of all i use RBD to FBX rop to separate points. And it works well. For positions, but rotations are zero. For example, when i export to alembic, then from alembic to fbx in cinema, i have right positions and rotations. How could i delete alembic and cinema from my pipe? The only thing that comes to my mind is to export a json or txt file from houdini with all the points+rotations - and import via script in unity - this way you can add all kinds of attributes - but i guess there is a better option 1 Quote Link to comment Share on other sites More sharing options...
