Houdini mantra shadow~
874604650
disable the shadow casting on another object (with use of Render visibility or Categories). if you want to be more specific in a way that a certain object only cast shadow at selected objects while others are excluded, you will have to render more passes. currently i know no easy way to do this in one go (in mantra).
