Vex: Create a vector/quaternion with literals (x,y,z) and (r,g,ba)
In Vex I create a vector as following:
    v@test = set(1,2,3);
However this results in vector with indexes
(test[0], test[1], test[2])
How do I have it so that i actually uses literals
(test[x], test[y], test[z])
Edited by schiho
You can address the components of vectors using v@test.x, v@test.y, v@test.z in VEX. If you mean the appearance of the vector components in the Geometry Spreadsheet, you can use the setattribtypeinfo() VEX command to set the type to one of the defined types in the help page: http://www.sidefx.com/docs/houdini/vex/functions/setattribtypeinfo.html
