multiple volumes used as AOV for main volume
I have a main volume that I want to render. however In that volume I would love to be able to merge other volumes into it and use those volumes as extra image planes. This means that my second volume should NOT show up in my beauty pass, but be available as an AOV. is this possible?
Right now I have it setup so I render the second volume separately, but I wonder if the other thing could be done?
Here is an example file to create custom aovs for different volumes, the workflow is a bit cumbersome because you can't reference the volumes directly from sops but from a geometry file. The main thing is to activate your hero container to sample the volume aovs.
I hope it helps you!
Thanks,
Alejandro
volumeAOVs.hip
Edited by Pazuzu
You can also use the "op:" expression (e.g. op:`opfullpath("../../yourVolume/OUT")` ) in the filename to direct to a sop, so you don't have to save your volumes/vdbs to disk first.
Edited by Gorrod
Sorry but that's not possible! Because Mantra will not find the path to the node.
It's actually possible to use op:/ syntax to point at SOPs in a shader, as long as the SOP is the output (or upstream of the output) of an object listed on the Mantra ROP. If you don't actually want that object to render, you can add the vm_renderable flag to the container and set the value to 0.
Yeah I know! I was meaning that not directly, you need to tweak first to make it functional. Even when you tried to render that's what the command line tells you! I didn't explain my self correctly! :)
