VOPSOP addAttribute VS AttributeVOP
Hi, I have been trying for hours to make my glued object stick to the ground by using an old VOPSOP method.
(When the sys starts my object crumbles immediately)
Everything works fine with OLD set up but I want to figure out how to make it work with the new AttributeVOP
Cheers!
Images and hipfile UP thank you.
glue_to_ground.hipnc
Edited by worldcmt
files attached
  On 8/4/2018 at 5:03 PM, Skybar said:
'Add Attribute' simply adds an attribute. If you want to write to an existing attribute either use 'Set Attribute' or 'Bind'.
Hi Skybar, first of all thank you for the answer.
I tried using the set attribute and bind but nothing seems to work.
Now I am a little more confused. Add attribute help me to create the attribute (that is what I need first) but it won’t create it because I don’t know if my “if” statement is right.
Set attribute should go after the add attribute to set it up?
Hous and hours and I can't find the way hahaha
