Valent Posted August 4, 2018 Share Posted August 4, 2018 Hi) Can I somehow get the maximum(and the minimum) value of an attribute in VEX? I want to use them in a FIT function. Quote Link to comment Share on other sites More sharing options...
toadstorm Posted August 4, 2018 Share Posted August 4, 2018 not easily. just use attribute promote sop for this. 1 Quote Link to comment Share on other sites More sharing options...
Popular Post konstantin magnus Posted August 4, 2018 Popular Post Share Posted August 4, 2018 You can fit-range an attribute with setdetailattrib() set to "min" and "max". 1st pointwrangle: setdetailattrib(0, 'height_min', @height, "min"); setdetailattrib(0, 'height_max', @height, "max"); 2nd pointwrangle: float min = detail(0, "height_min", 0); float max = detail(0, "height_max", 0); @Cd.g = fit(@height, min, max, 0.0, 1.0); fit_range_VEX.hiplc 11 4 Quote Link to comment Share on other sites More sharing options...
Valent Posted August 5, 2018 Author Share Posted August 5, 2018 Thanks, have tried both suggested variants, and I like Vex pipeline a bit more. Quote Link to comment Share on other sites More sharing options...
konstantin magnus Posted October 8, 2021 Share Posted October 8, 2021 Uniformly scaling an attribute so its maximum is 1.0: 1st point wrangle: setdetailattrib(0, 'height_max', f@height, "max"); 2nd point wrangle: f@height /= detail(0, 'height_max', 0); 1 Quote Link to comment Share on other sites More sharing options...
damonmaster Posted October 22, 2021 Share Posted October 22, 2021 How can I set and get in one node,because sometime need execute this every time in the loop。 Quote Link to comment Share on other sites More sharing options...
