plazadelmar Posted August 10, 2018 Share Posted August 10, 2018 (edited) I'm emitting smoke with colors. After adding and creating dop fields import with density, vel and Cd channel for rendering the colors are not visible in the render. When I'm visualizing them as color channel everything works fine. How can I make volume colors visible in Redshift render? Edited August 10, 2018 by plazadelmar Quote Link to comment Share on other sites More sharing options...
jmay823 Posted August 27, 2018 Share Posted August 27, 2018 I would like to know the exact same thing. Maybe there is an expression that can be written for the tint parameter color of the scatter? I suppose you could render out each parameter as an AOV and color in comp but it doesn't help with the beauty render. It seems that the RS Volume node is limited in this respect unless there is a technique that I am unaware of. Perhaps someone out there is willing to share how they circumvented the issue? In contrast, all of this stuff is really easy to dive into nodes in mantra like basic smoke and constant volume which both pickup CD attributes by default. Quote Link to comment Share on other sites More sharing options...
Sepu Posted August 27, 2018 Share Posted August 27, 2018 Check out this topic on the forums https://www.redshift3d.com/forums/viewthread/13007/P15/#103643 1 1 Quote Link to comment Share on other sites More sharing options...
jmay823 Posted August 28, 2018 Share Posted August 28, 2018 11 hours ago, Sepu said: Check out this topic on the forums https://www.redshift3d.com/forums/viewthread/13007/P15/#103643 Thanks this is helpful. It's not optimal but I'll definitely try the thread as a workaround. Quote Link to comment Share on other sites More sharing options...
