Full path from lens shader to detail attribute
konstantin magnus
I wrote a lens shader in CVEX that is supposed to get some data from geo level (ie. a position to look at).
Unfortunately no full path expression on my shader node does seem to work:
detail("op:/obj/mesh/OUT"), "center", 0)
Edited by konstantin magnus
screenshot
Hmmm...am I seeing a parenthesis mis-balance?
detail("op:/obj/mesh/OUT", "center", 0)
The camera is just a single point, what if you stored the data on the point instead of detail?
point("/obj/cam1/camOrigin","center",0)
Oh wait a second, are you fetching from inside the object? I think detail can't reach inside SOP, it would sit at the obj level.
detail("op:/obj/mesh", "center", 0)
Edited by Atom
