Using custom Python modules
art3mis
Hi
Is anyone aware of any good beginners tutorials on using custom Python modules with Houdini?
Have been trying now for days to get ytini http://www.ytini.com/getstarted.html
working in Ubuntu, but whatever I try always end up getting
'module not found'
 when I do an
>import yt
in the Python shell.
Edited by art3mis
I had same problem when I was trying to load  module .Then i got help from Doc.
This is from Doc:
In general, Houdini looks for "scripts" (usually callback scripts) on disk under HOUDINIPATH/scripts/, while modules you would import are under HOUDINIPATH/python2.7libs/. Unfortunately, this is not consistent, so for example Houdini looks for the pythonrc.py initialization script in python2.7libs.
for more : http://www.sidefx.com/docs/houdini/hom/locations.html
24 minutes ago, art3mis said:
Thanks!
Couple other noob questions
In the Python Shell what is the difference between
os.environ['PATH']
and
sys.path ?
And if you type
os.environ['PYTHONPATH']
What should it return? (assuming you haven't altered PYTHONPATH)
os.environ['PATH'] : refers to the PATH environment variable, which is a list of directories the operating system tries to find an executable in if you try to start an application without an absolute or relative path like  you can set PATH environment variable to houdini bin directory , then you just type mplay in cmd to run mplay.
os.environ['PYTHONPATH'] : https://docs.python.org/2/using/cmdline.html#envvar-PYTHONPATH
sys.path: are the directories Python searches for modules in when you try to import one
I hope It will help.
Sorry I couldn't reply to your other thread. Did you try to install yt using the pip install method ?
I didn't have conda installed so I just tried to install using pip real quick and I was able to import yt fine in Houdini. Could you give that a try and see if it works ?
-J
Edited by animknight
Thanks!
used the install script.
Are you on Linux?
I am fairly confident ytini is installed correctly.... but Houdini doesn’t seem to recognize the path I have set... trying to troubleshoot in the Houdini Python shell but not a Python guru.
For instance the instructions suggest doing an
import yt
but isn’t import only for modules?
I've tried every possible permutation if setting PATH and even trying to set PYTHONPATH
Edited by art3mis
  • 4 weeks later...
