Masoud Posted October 18, 2018 Share Posted October 18, 2018 Hello; Poly-Bridge SOP connects edge-loops automatically, but I want to pair them manually. Is it possible? Thanks for helping. PolyBridge.hip Quote Link to comment Share on other sites More sharing options...
Noobini Posted October 18, 2018 Share Posted October 18, 2018 easy.....but hacky..... 01) look at your spheres...they are nicely ordered left to right because of your copy/transform 02) look at your cylinders.....even tho they are also sort of left to right...you've screwed up the order in the merge So quick solution is in your merge, click the arrows so that you have transform2 on top (ie the cylinders are also left to right)...and that's it... Quote Link to comment Share on other sites More sharing options...
