SOP/DOP constraint question
Mjag07
So I'm digging into the new H17 fracturing nodes and have run into an issue. It's possible that I haven't set it up correctly.
The main issue is I set the constraint strength in Sops to 1 for testing to make sure everything is working correctly. I set the strength to -1 in Dops.  Which is shouldn't break but it does. Any ideas on what's going on would be awesome.
I attached my test file which is not super clean atm.
StrengthTest_a01.hipnc
Or maybe I'm looking at it the wrong way. My thought would be you want to control the final strength in Dops not Sops.
Mike
Edited by Mjag07
