Change some H17 Defaul Settings
Hey guys, is it possible to change some of the new default settings from H17?
Things that botter me are:
- Origin Gnomon visibility (can it be off by default?)
- Flipbook Resolution Settings (i'd like to keep it off)
- Object Merge Sop / Relative Path (It was much easier for me when it was off by default)
Thx
  1. You can turn the Origin Axes off and then select Save as Default (highly recommend doing this in a fresh Houdini session)
  2. This setting can be saved to the hip file, but can't be saved as a preference.
  3. I don't think you can change the default setting for Export Relative. It's on by default for HDAs - absolute paths are a pain if you go to convert a network to an HDA.
