tious13
Vellum Cloth and String weld
Hi guys, I'm playing around with vellum but something is bothering me:
I want to attach a string to a cloth but I cannot do it if they are 2 different vellum objects in DOPs
The example file will be much clearer than what I write but the question is:
Does all the vellum objects need to be merged to build a constraint network, am I using the wrong method meaning I should create the constraints in another way ?
Thanks for you help !
cloth_and_string_01.hipnc
Share this post
Link to post
NO NEED ANY MORE!!!!
Hi, I sucessfully stitched cloth and string together. But I couldn't stich the ohter end of the string to a rigid body. How does that work? I also wanted to make the system a bit more complex with more clothes and strings connected at different points to each other? Is this possible?  Thanks a lot!!!
Sorry!!!
Edited by dominiksartor
solved the Problem!!!
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
