temzy Posted October 31, 2018 Share Posted October 31, 2018 Hey there, I'm doing some RND on destroying a building with a force. And I'm wondering what's the best way of using constraints. Is glue used with minimal strength just for holding geo together and then using cone/hard constraints? And what about constraints between clusters? I believe the strength between clusters must be low and for the clusters really high, but do I have to use also cone over cluster constraints? Are cluster constraints even necessary if you use cone/hard? I'm just confused and can't decide how to use constraints properly. I would really appreciate if you guys can give me some tips on that. Quote Link to comment Share on other sites More sharing options...
char Posted November 2, 2018 Share Posted November 2, 2018 http://www.appliedhoudini.com/ Quote Link to comment Share on other sites More sharing options...
samkaz123 Posted November 3, 2018 Share Posted November 3, 2018 dont get confused you are on the right track...its not important that u must have cluster ...unless you want something specific ...in the start try to do basic..dont over think...about what else you can add...just think about a basic destruction..and it dont need to be a big building..its can a small wall..try there...and go on to the bigger and complicated stuff with more constraints and there different works...just take it easy in the start..it took me 6 months...to get from a small box fracture to house destruction from a tank..with all kinds of constraints and active body...and good luck...and am also a student.. Quote Link to comment Share on other sites More sharing options...
