access @ptnum from second wrangle input?
How can I access the ptnum of the points coming in though the second input of of a wrangle?
I tried to do it with a point expression but i don't know what to put for the atttibute_name.
s@name = point(1,"ptnum", @ptnum);
I want to concat the second input's point ptnum with the first input's name attribute after a copy to points sop.
the copy and transform sop creates a copynum attribute which works to rename copies. but copytopoints doesn't
How can i do this?
thanks
The result of this point call would be an integer. So try...
int local_ptnum = point(1,"ptnum"@ptnum);
s = s@name;
s@name = sprintf("%s_%03d",s,local_ptum);
This will zero pad the point number by 3 digits.
Edited by Atom
I'm perhaps misunderstanding the question but if you lookup the point number of a point in another geometry using @ptnum, it's always just going to give you the same value back, no?
You're basically saying 'what is the point number of the point numbered @ptnum'
*edit*
Besides, I don't think you can look up point number. You could give the geo in input 1 an id attribute to mirror the point number and look that up, but still if you say 'what's the id of the point with number 3' it's just going to return 3.
Edited by j00ey
