arnold shaders not showing on tab menu
hey!
I just installed arnold 5.2.1 on houdini 16.5.571, it works fine *but* shaders are not in the tab menu in shop context, but if I manually install a digital asset library and browse to the standard surface otl file and choose to "install and create" the shader is there and is working!, just not appearing in the tab menu
doen anybady experienced this before?
any workaround or a way to manually add those nodes to the tab menu?
cheers!
Hi.
if you delete the houdini.pref in the:
C:\Users\"your user name"\Documents\houdini"version".0
it may biuld the tool bar for you ??
This file:
C:\Users\JUMANGIC\Documents\houdini17.0  = houdini.pref
I do make a copy , anyway it is just a sugestion:
M
  • 1 year later...
On 11/13/2018 at 1:52 PM, nicoladanese said:
hey! problem solved, this is what they replied from solid angle
We removed the depreciated shaders from the root SHOP menu.
You will find all the shaders after creating an Arnold Shading Network, and creating your network inside that VOP network.
https://docs.arnoldrenderer.com/x/2IBQAg
Thanks
hey dude i was struggling with this problem for 4 hours your comment just saved me :) , such simple thing i wasted 4 hour searching around internet ;(
Edited by PaPaBert
