ROP Fbx. Export as separated meshes.
Crisis
Hi.
Can I export fbx as separated meshes?
I have problem with ROPfbx. After export merged object I have only one mesh when I open it in Maya.
Exist a possibility to not merge them at all? I see that alembic recognise parts by name attribute. But fbx has problem with that.
  • 2 years later...
You need to enable ROP FBX Output's "Build Hierarchy from Path Attribute". For it to work you need to first use the Name SOP with "Attribute" set to `path` and "Name" set to the FBX path of your object.
For example if you want this structure when exported:
-Parent
	|- Child A
	|- Child B
		|- Child C
You'd set the "Name" variables in the Name SOPs to
Parent/Child A
Parent/Child B
Parent/Child B/Child C
  • Like 2
