MitchFields Posted November 16, 2018 Share Posted November 16, 2018 Error - Glue constraint references unknown object Would really mean a lot if someone could take a few minutes to look at this file. I was trying to recreate richardlord's spring constraint thingy, but had trouble even beginning to get it to work in the first place. I think there's some changes in constraints from 15-16 (im working in 16). I should have the name attribute matched up to all my constraints and all my objects as the same, but for some reason I get an error with, 'unknown object'. I thought it may have been that the constraint was looking for @rest? Not sure. Very new to creating attributes that get used in dops, I appreciate any insight. springConstraint.hipnc Quote Link to comment Share on other sites More sharing options...
vicvvsh Posted November 17, 2018 Share Posted November 17, 2018 Hi Mitch, is this kind of spring effect you are trying to achieve? If yes then why with glue constraint? I attached the file with modification. The new nodes are light green and nodes where i changed something are blue. springConstraint_01.hipnc Quote Link to comment Share on other sites More sharing options...
MitchFields Posted November 17, 2018 Author Share Posted November 17, 2018 (edited) Oh dude! Thank you so much man I didn't realize there were different constraints. This is exactly what i'm looking for! (was accidentally confusing the data names with the different constraint types) Edited November 17, 2018 by MitchFields im dumb Quote Link to comment Share on other sites More sharing options...
